Niagra Falls with Diesel Fuel
My pump went to heaven today on my way to Los Alamos. I noticed my fuel gauge moving faster than my old HEMI Road Runner's used to, so I pulled over and saw a flood coming out of the front of the VE. I limped it to Santa Fe, Filled up the tank and headed for the nearest Bosch repair place (Albuquerque), but the truck started running extremely poorly about 15 miles from town. I drove it anyway, making 25 MPH and leaving a snail trail the whole way. Couldn't find a pump in town so I ordered one out of Oregon, and limped home to the mountains, trying to keep the temp under 900f (post turbo). I don't think the truck is damaged otherwise.
My Question(s),
How should I adjust the new pump, and did turning up the fueling screw on my old one lead to it's demise?
Where do I get the governor spring, and will the higher revs cause ring brakage on the cylinder ridge?
Thanks!
Mark
My Question(s),
Thanks!
Mark
I doubt the fuell screw hurt anything, Ive had mine cranked down for a million miles and no problems, post turbo temps under 1100 is OK.
On the spring, I think Piers has them. How high are you reving? 3000 isnt going to hurt things.
I don't know how high I'm reving it, because I haven't put in a tach yet. I wrap it till I just start to feel the governer, then shift (this is hard acceleration of course).
Who is Piers?
Who is Piers?
I pulled my old pump today and founf the massive leak was caused by a missing plate on the engine side and bottom on the pump. Both the screws are broken off flush with the pump body. I can't figure out what could have caused this to happen.
12valve
Dec 25, 2005 01:29 AM
JoshPeters
53
Oct 14, 2004 12:36 PM
