New Tires on Back???
I am in my 40s and for my entire life, I have been putting new tires on the front of my truck and then moving the old front tires to the rear, where they get eaten up pretty fast for some reason. My rear tires look like someone ran a cheese grater over them after a few months of driving. This has always worked well and my father always impressed upon me the importance of having good tires on the front, since it not only did most of the stopping but also the steering. I also reasoned that you would want the best tires on the front, so that when in 4wd you would be pulled rather than pushed adding to stability.
All that being said, I am seeing many people say that you would want your newest tires on the rear, meaning less traction and that when in 4wd your back end would be pushing you faster than the front slightly meaning less stability. This makes no sense to me. I would think the newest and slightly larger tires should always go on the front.
4x4 trucks like the same size tires front and back, unless you only use 4x4 in very low traction stuff, like ice.
It is best to buy 4 matching tires for 4x4 trucks.
You chain driven, aluminum cased transfer case will thank me.
I do put the same size and brand of tire, but the new ones are going to be about an inch bigger in diameter. I have over 200,000 miles on my transfer case without it ever needing service.
I will continue to use matching size tires for my 4x4 trucks.
I have to replace tapper cover gasket on my 2002. Can someone tell me what all other
Can someone tell me what all gaskets I'll be needing. To change tappet cover gasket on a 2002 year model?
I would ask over on the 2nd Gen section, but you'll have a big job ahead of you since you will have to remove everything from the LH side of the motor to get at the tappet cover.
Received 1,637 Likes
Well, for future reference, if your transfer case decides to quit on you, I'm sure Oliver has a few spares on the shelf to send out to you when it happens.
Another thing no one has addressed, to me putting new tires all the way around then rotate them every 5,00 miles, rear tires straight to the front then put the fronts on the opposite sides in the rear. You don.t get a wear pattern that way and they all wear nice and even.
Yes that is a good idea. He could also have a problem in the differential that is not letting the rear wheels turn at different speeds when cornering. This would chew up the tires as well.
nonrev (12-02-2018)
We had that problem with the wife's 98.5, turns out when she had the fluids changed in the diffs and tranny, transfer, they didn't put the additive in for the posi rear so it was grabbing like a bugger.
As for the transfer case, you have a part time 4wd system so your TC isnt subject to any differences in tire diameters while just driving around. But when in 4wd those diameter differences will cause a significant driveline speed problem which means you can ONLY run 4wd while on loose or slippery surfaces. Running on dry concrete in 4wd is never good no matter if your tires are all matched or not, but running with odd size tires will over time tear up u-joints and transfer case chain. Hope that helps you out...
05-29-2009 10:24 PM
sakisaki400
23
12-31-2006 10:17 PM
JoshPeters
04-03-2005 08:13 AM
