New pump,idles ruff
New pump,idles ruff
After sitting for some time,upon starting rhe pump leaked around head. Thought Id be ahead buying new pump. Now no leakes but truck doesnt idle as smoth as it did and gets worse as i slowly increase the rpms.
Under power its ***** out. Runs great. Tryed adjusting timing from late enough so wouldnt start to all the way to the head.[real noisey]
What ya thinking?
What ya thinking?
What ya thinking?
What ya thinking?
The following 2 users liked this post by maybe368:
Diesel tinkeler (01-28-2018),
edwinsmith (01-28-2018)
Wouldn't that exclude the lift pump from the leak test? Did you bleed the system with the electric pump running, in order to relieve any air already in the system? If you did, then it is probably not the lift pump, if you didn't it could still be. That also includes any other leak source from the tank to the lift pump...Mark
What ya thinking?
What ya thinking?
The following 2 users liked this post by nascar mark:
MrFusion (01-28-2018)
I would ditch the diaphragm pump and go with a low pressure piston pump. Less prone to catastrophic failure. I would think that Nascar Mark maybe right though. I had a similar problem and fix to what he described with a Kubota D600 engine.
Capp35
10-27-2005 03:28 PM
bkrukow
09-12-2004 03:32 PM
