new looking at purchase ????
Old Dec 8, 2009 | 06:59 PM
1v6pony's Avatar
ok I am looking at a 1993 250w CC auto trans.
test drove it, and at 30-35 mph it started shaken real bad not in the sterring wheel, any ideas? could this be caused from a sloppy joint at the steering box.shaft.. It is very sloppy..
the heater turns on for like 5 seconds, the air comes out the dash vents hot, then it slowly stops and only comes out the lower vents cold, any ideas
also after 15min of warm up try to go into reverse ,it almost seams that the trans is sliping and then all the sudden goes into motion. PS I did let it warm up for 4min in neutral... any ideas...
thier is no rust, it has 209,000 miles clean body he wnats 4K but is a friend and will let me make payments....want to see what you all think...
I have been looking at the forum for days, when I found out I might be getting this rig... what a great site....
Thanks Brad
Old Dec 8, 2009 | 07:34 PM
That's too much for a truck that needs a trans.
Old Dec 8, 2009 | 08:25 PM
1v6pony's Avatar
so from what i discribed, you think the trany is bad?? could it just be an adjustment?
Old Dec 8, 2009 | 08:26 PM
No, it sounds like the direct clutch is toast.
Old Dec 8, 2009 | 08:30 PM
1v6pony's Avatar
direct clutch/ do you mean the clutch band?
Old Dec 8, 2009 | 08:53 PM
93 12v's Avatar
Check the sticky for tranny info. BC847 has a great writeup with pics of a rebuild. Check the fluid. I think wanna is right.
Heater could be vacuum leak or poorly functioning blend doors.
Front shaking? Rear? Could be any number of things. Brake rotors/drums, bearings, ball joints/kingpins, bad tire........
4k sounds high......Do some research at kbb.com or nada.com to find top value, then deduct cost for repairs, then you'll get an idea of what it's really worth.
Old Dec 9, 2009 | 06:25 AM
Sounds like its worth about $2700
Old Dec 9, 2009 | 10:18 AM
1v6pony's Avatar
well thanks guys, I know he still needs to sell it, so I will see what he want's to do... he has a lot of connections, so maybe he will fix it to sell it to me for the $4,000... guess I am not part of the club yet....LOL
Old Dec 9, 2009 | 05:32 PM
93 12v's Avatar
Stay with the site. It'll help you in your search. There's even a classified section up top.
drumguy89
Oct 5, 2007 07:07 AM
Common
May 28, 2007 09:36 PM
RAW
15
Oct 10, 2006 02:00 PM
frogspit
Apr 20, 2006 01:06 PM
Next0n
Apr 20, 2005 06:45 AM
