new headlight switch Now no parking lights
I was driving home and the headlights turned off then on again then off and on . Sounded
like a circuit breaker tripin somewhere under dash or hood . So I changed the head light switch and now I have no parking lights . when I turn the H Lights on they work but no other light do . I can pull the switch about half way from off and parking and the lights come on but if I pull to first or second click they go off . Thank you for your BRIGHT ideas |
Sounds like a bad switch.
Hi Dave , I just tried a new switch again . Still no parking . Thanks
Can you bypass the light switch and put two toggle switches in . One for the headlights
and one for parking lights . If so what wires go together . When I get time I will just buy a new harness and do it right a few years from now ha. Thanks |
My guess is that you popped the parking light fuse while changing switches. Check that fuse.
A dime in the cigarette lighter pops the parking light fuse very nicely, too. |
Thank You Dave For The Help ...you Are The Man You Fixed My Problem . I Checked That Fuse And It Looked Good . I Then Put A New Fuse In And It Worked . I Now Can See The Light ...thanks Dave And Dtr
(Post 1473490)
Speaking of headlight switches how do you get the black nob on the end off so you can take the black plastic piece that its atatched to on the dash off?
Originally Posted by Underpsi
(Post 1473929)
If need be, look at a new switch and you'll see it, makes it easier to find . |
Originally Posted by GIT-R-DONE
(Post 1473819)
(Post 1473490)
