new diff bearings- setup
Can anyone here give some advice on re-bearing a dana 70U?
It appears to have a set of aftermarket bearings in it already. The carrier was zero-play but came out pretty easy. So, I'm guessing it will need a bit more pre-load.
FSM says carrier preload =0.015 and the DANA 70 manaual states =0.010??? What gives? It seems like the DANA specs are different on almost everything over DODGE?
Hoping that pinnion depth will be correct and not need changing- only play with pre-loading shims.
Michael
Michael
Wel... I guess well see. If came apart easy...
If needed I'll fab some spreader bars. I saw mixed discussions on some ppl love them and some do just fine without. Maybe the 5# deadblow is key in working the carrier in the housing.
If you are at zero ring gear clearance- drop 0.010 on the other side .. it should come close to 0.005 clearance. 15 ~ 0.0075. Understandibly, if you open the case.. and shim. THen your sliding it in- zero clearance instead of interference fit.
I can make a set of master bearing cones if needed.
Did you have to change pinnion depth with new bearings????
M
M
Mutt68
Sep 25, 2012 12:51 PM
banana
Dec 1, 2009 11:44 PM
