Need some opinions for my future torque converter
Old Dec 16, 2010 | 03:05 PM
Originally Posted by 92smokin blacky
How well is ATS's tqs made? I found a used one around here for a 47rh for pretty cheap.
Like everyone elses ats just paints them purple and asks a million dollars for them.....Tater93 has a non lockup one in his 518 and he said it's not that great but i've never heard anything bad about lockup ones.
you doing a 47rh swap?
1ST General's Avatar
Thumbs up
Suncoast X3 !
Old Dec 16, 2010 | 04:10 PM
BC847's Avatar
1st Generation Admin
Originally Posted by JDP
^^^^ I'm curious as well. For those who are running a Suncoast, how impressed are you?
I can't comment on anything other than the SunCoast. Here's what I said on 09/05/2007 after I first installed the SunCoast unit during a general trans overhaul:
Originally Posted by BC847
After driving it around more tonight, I can offer these observations ~
- There's definitely a better "Connection" between the engine and the ground as the throttle/engine presents with more responsiveness (Does that make sense?). There's a new-found notice of slight engine-braking when letting off the throttle. I'm having to re-learn some aspects of driving normally with the new throttle response.
- Not sure how to word it . . . . . . The waste-gate controller is set to 38psig. Historically, that's where it hung under full throttle. I'm all of the sudden able to push the boost up to 40psig, maybe 41, or 42 even. There's a marked increase in turbo-bark with letting off a full throttle quickly. I can hear a new low tone in the in-cab sound of the exhaust system (remember, it's a quiet system).
- While technically, I didn't change anything about the valve-body this time, the transmission seems to be shifting a bit early under a full throttle. I realize that with the OEM converter being so loose, I was "blowing through" a good deal, so it may be I just need to re-learn it all. I dunno. It seems the engine wound-up a little tighter before and perhaps was better realizing the HP peak.
(EDIT: Tweaking the TV cable corrected the shift-point mess)
It's funny how literal the term "Seat-Of-The-Pants" really is when judging subtle changes as such. My SOTP gauge is all the more skewed with the new transmission mounts. I can tell a BIG difference in the "tightness" of the drivetrain's connection to the truck.
I've beat the crap out of it since.
That being said, I eventually broke the intermediate shaft (This past start of spring or so '10). I had the good folks at SunCoast open up the converter, clean it and "tighten" it a little. Doing so better placed the stall in relation to where the engine's torque peak is.
At this point, I don't know that it could get any better (the converter).
I do know I couldn't get any better customer support regarding the converter and the trans for that matter. Erny (the Chrysler trans guy) listened to my feedback about the truck/trans and what I wanted and working with their converter guy, was able to get it just right as far as I'm concerned.
Old Dec 16, 2010 | 05:08 PM
Onemoparnut's Avatar
That is great to hear that someone still has good customer service that is hard to find anymore.
Old Dec 16, 2010 | 05:47 PM
Lucas1's Avatar
Originally Posted by #2isgreen
i went all out and got the $950, stalls real low. only time i ever go over 2000 rpm is when I'm in OD or having a little fun. if you are towing you may want the extra rpms of a looser converter so you can keep the turbo spooled up.
what kind of turbo?? now with the stall being that low does it feel like your not in the trucks rpm curve??is it lugging too much.
i dont understand what the best balance point is for spooling the turbo VS. too low of a stall.and putting the power to the ground.
does anyone know what differences the stators and internals are between brands..actual knowlege not opinions..
BD claims to have their own and TCS as well........how much difference could they all be??
$950-$550......................are the internals that different.
and on a side note bd's new "diverter "valve would solve any spooling issues.
so the tightest convertor you would think is the best choice.
Old Dec 16, 2010 | 07:02 PM
92smokin blacky's Avatar
yep sure am. for the price, don't think i could go wrong with it and i've had good luck with ATS parts so far. I wanna at least get a shift kit and torque converter in before i put the 47rh in.
lniemeyer2
Oct 24, 2012 12:11 PM
93dieselZak
Jun 16, 2011 06:10 PM
rossco
Aug 23, 2007 06:17 PM
mainer
Jul 17, 2007 07:13 PM
