Need a measurement...harmonic balancer
I trying to install my tach kit, and I need to put the magnets 180* apart. I can't get an accurate measurement, so I'm hoping someone has a spare balancer, or a motor they can get easy access too.
My motor is a 89, so not sure if a different balncer was used for Non-IC and IC trucks?
Once I have the measurement I can use basic math to figure out 1/2 my circumference, then cut a piece of tape to the exact measurement, lay it on the balancer and viola...180* apart!!
Well I ended up using an old seamstresses nylon measuring tape I forgot I had in the top of the tool box. My balancer measured out at almost 26" circumference, so I made a mark then taped the nylon measuring tape at that mark, measured 13" and made another mark...done!!
Applied the 2 part epox and magnets, now will wait 24Hr or so to let it set up, not that I need to fire it up since it's up in the air with no upper control arms or tie rods....
Thanks for the advice guys.
Tuckerdee
Nov 11, 2008 10:32 AM
