Need Help
Old Feb 17, 2014 | 08:17 PM
12valvepr's Avatar
Need Help
Ok so i just got done putting a new lift pump in my truck because i was having issues with it starving for fuel and dieing on me. After putting a new lift pump and fuel filter on it it runs but it seems gutless and like theres not as much power there as there should be.
Just this last summer I turned the pump up alittle bit along with the smoke screw and it smoked alittle bit but now it doesnt seem to smoke as much as it did.
Old Feb 18, 2014 | 06:52 PM
sshort's Avatar
Check the fuel pin make sure it is not stuck
Old Feb 18, 2014 | 08:13 PM
rrgrassi's Avatar
Also check for air in the fuel lines.
Old Feb 18, 2014 | 08:51 PM
simplysmn's Avatar
And check for a cracked line or loose Line . it does Happen . ask me how I know .
Old Feb 19, 2014 | 10:50 AM
cougar's Avatar
Boost leaks. Restricted intake and/or exhaust.
Old Feb 19, 2014 | 01:25 PM
12valvepr's Avatar
If it wasnt getting the air it needs wouldnt it blow more black smoke because the air to fuel ratio will be off?
smokin24v
Mar 18, 2008 01:21 AM
pwrtripls1
Feb 8, 2008 07:25 PM
spooling
Sep 13, 2007 10:05 PM
coupdetat
Jan 17, 2007 09:23 AM
