nasty oil leak
From my experience my dad's truck started with a slow leak which gradually became a big leak and would leave a 1ft puddle before he changed it.
You might check your rear valve cover to see if its leaking, but if its not its trans removal time.
If it gets worse when the engine is running there is a good chance of being the rear main. As the crank spins it would probably allow slightly more oil to pass by. This will not cause any major problems aside from an oily undercaridge. Also be sure to make sure the oil is always full or you will have major problems.
quadman20
Feb 5, 2010 08:49 PM
deezulsmoke
15
Jun 5, 2005 02:47 PM
Do check the valve cover just to be sure, though. I just installed a new one in mine today, along with a fricken huge speedy-sleeve
