My new 32x48 1st Gen Storage Facility.... ;)
#31
The shop package arrives Monday morning....so my guess is by next friday the structure will be up and done, then it's prep for the slab, and I checked the drawings and it calls for several inches of crush, then a couple inches of drain rock and then a layer of rigid insulation before the rebar and then finally concrete to top it all off.
#32
be hard to argue with a home owner standing there with a 4X4 on his shoulder.......
thrashingcows (06-23-2018)
#33
Received 1,637 Likes
Not to sound negative, but why in the world are the drains in the middle of the pathway between the new and old buildings? Or are they below grade, and you don't see them.
#35
When you were discussing the project, was a covered what we call a " breezeway" ever ventured upon? It would be nice on a -32* c night to go out to the mancave without entering the weather....
Oh yeah, I'm still way green with envy.
Lol
Lol
#36
naw.....he's still in shorts and a T shirt on days like that
Blue Goose (06-23-2018)
#38
Think the side door on the current garage and the new shop side door will almost be in alignment so I will most likely one day put up a little roofed structure to stay out of the weather when passing from one to the other.
#39
Looks great. The only thing I can mention is to put a vapor barrier somewhere below the slab. The rigid insulation might do the trick, but seal moisture from coming up into/through the slab and you will always be able to coat the floor if you want to.
thrashingcows (06-24-2018)
#40
Good point. I used 6 mil plastic with 2 inch blue board over it on my shop slab pour.
#42
Yeah it's nice and sandy....great for drainage and compaction, absolutely the perfect stuff they said for building on.....Can't complain at that! Few miles from where I am located they are doing another shop and it's all clay they told me, just a mess and a major PITA!
nonrev (06-24-2018)
#44
My shop has radiant tubing that I installed myself with the help of a friend. I thought it was, cheap, easy to install and the best heat source hands down.
I heat mine with a outdoor wood boiler. I go through a lot of wood, but by heating the massive amount of concrete in my shop the heat stays the same for along time.
I can loose power for a few days. in winter and the temp. in my shop only goes down a few degrees.
The other thing I love is water evaporates off the floor quickly and it is warm to lay on, which the dogs also love.
The following 2 users liked this post by oliver foster:
death row dave (06-30-2018),
#45
Thanks!
A lot of my budget and time was getting where T-cows was the minute he dug his hole.
You are going to love the 1st gen storage facility!
