Mud flap suggestions?
I just flunked my "safety" because I have to have mudflaps- even though everything stock, it's a Hawaii thing I guess. This thing has never had them, Is there a stock option? Anyone else had to install them? I would like something halfway decent at least LOL. Or easily removable after the safety check.
I get mine from Amazon...They're required in Texas on duallies...There's also a maximum height from ground requirement...[whistle]...Ben
Originally Posted by Fordzilla
(Post 3383733)
(Post 3383734)
HMMMM. When was this enacted?
(a) Safety guards or flaps are required on all trucks, trailers, or semitrailers (in combination with a towing vehicle), if the rearmost axle of the vehicle (or combination) has four tires or more, or at least two super single tires. They are not required on buses, pole trailers, motor homes, or truck tractors. In this section, "super single tire" means a wide-base, single tire that may be used in place of two standard tires on the same axle.(b) Safety guards or flaps shall be located and suspended behind the rearmost wheels of such vehicle or if in combination behind the rearmost wheels of such combination to within eight inches of the surface of the roadway. (c) A tolerance of four inches will be allowed. (d) Safety guards or flaps shall be at least as wide as the tires they are protecting. (e) When trailers and semitrailers are operated in combination with a towing vehicle, safety guards or flaps will be required on the rearmost axle of such combination. (f) Safety guards or flaps shall be of metal, rubber, rubberized material, or other substantial material, capable of remaining in place back of rear wheels by their own weight or structure while the said vehicle is being operated. (g) The construction of safety guards or flaps will be such that they will remain in proper place back of rear wheels and will be rigid enough to prevent slush, mud, gravel, and other roadway material or debris being transmitted from the vehicle's rear wheels to the windshield of the following vehicle. (h) Safety guards or flaps should be securely mounted, as wide as the tire that it is protecting, not split or torn to the extent that it is ineffective and the bottom edge of the safety guard or flap shall be no more than 12 inches from the surface of the roadway while the vehicle is standing still, or otherwise not in motion. (i) A flexible safety guard or flap may swing upwards and backwards while the vehicle is moving, so long as the safety guard or flap continues to block the trajectory of slush, mud, gravel, and other roadway material or debris which would otherwise be transmitted to the windshield of a following vehicle while both vehicles are in motion. https://blogger.googleusercontent.co...9/IMG_1563.JPG |
Any mud flap with Yosemite Sam on it telling people to "Back Off" should do.
(Post 3383737)
Originally Posted by Rug_Trucker
(Post 3383743)
45FMJ? Not 45JHP? :D
https://blogger.googleusercontent.co...8/IMG_1609.JPG https://blogger.googleusercontent.co...8/IMG_1633.JPG |
(Post 3383746)
I'm an old fashioned guy living in a new-fangled world...A peek past the newly installed fuel tank at the door pocket shows a glimpse at the 50 extra rounds of .45 ACP hardball for the Marlin Camp Carbine shown below that...If FMJ was good enough for the US military all those years, it's good enough for me...:patriot:...Ben
https://blogger.googleusercontent.co...8/IMG_1609.JPG https://blogger.googleusercontent.co...8/IMG_1633.JPG Is that one of them new fangled AR-SBR toys that everyone is yapping about, and I haven't seen or played with yet ? |
Originally Posted by NJTman
(Post 3383749)
Don't they differentiate between trucks and pickups?
Originally Posted by riki5156
(Post 3383751)
Yikes, next will be CDLs if you pickup lumber at home depot. Federal tax on your fuel, hours of driving restrictions. Sounds like they're really looking at safety.
What I did before getting rid of the horse trailer. Angle iron between the flap and bumper.
https://cimg6.ibsrv.net/gimg/www.die...98ac2f9c1e.jpg Thank you, BlueW250 |
(Post 3383742)
