motor built for work and a lot of playin
Old Nov 30, 2008 | 09:49 PM
randyswelding's Avatar
i got my hands on a 91 1/2 motor with everything even wiring harness.im trin to build it for workin the truck weighs in at 11,000 lbs every day(weldin truck) and want a motor that can make it from hell and back every day its gettin a s300 62/65/13 turbo and a airdog system for sure,what do i need to do cam,head,pistion and all that good stuff wise,lower compression?im lookin for 350 to 400 hp,keep in mind this is my first diesel build up so imay be alittle slow on terms and things,thanks for the help
Old Dec 1, 2008 | 04:09 PM
Well looks like you got alot of work done now, whats the spray pattern on 370's ?? like 6x16?
Id get a maxspool 2 cam , ive heard good about them and they lower egt's and make spool up alot quicker.
headstuds of course, new head gasket, possibly some custom porting work if you want to send the head out.
dont have to worry about pistons or lowering compression for 400 hp.
Actually for 400 hp you wont need any of this, big injectors and an hx40 and tuning could make 400rwhp. (rear wheel horsepower)
Old Dec 1, 2008 | 08:20 PM
pwrtripls1's Avatar
A basic 12 valve can make a reliable 400whp easily. Just takes minor pump tweeks, good sized injectors, and a good turbo. Your turbo choice looks good and if all you want is 400whp then the DDP+4's flow enough fuel to hit that goal. 6x16 injectors are way oversized if thats all the power you want to make IMO. Other than that just make sure the compression is good in all cylinders and the engine is more than ready.
Old Dec 1, 2008 | 09:10 PM
370's...... and i dont really know what they are.... i thought they were big 2nd gen injectors.
Old Dec 1, 2008 | 09:18 PM
all i know is there around 5x12s from the injecter chart on the firstgen site,i got the motor with the head almost off.im not likin ddp right now my fuel pin in scared and only been in the truck 2 months.i do kind of like the 370s.the set up will most likly be like it is now but new turbo and an airdog system for sure,ive been thinkin bout a cam but how driveable is it and around how much more power would that give me.im goin to the dyno later this week hopefully to get a baseline with this set up now
Old Dec 2, 2008 | 08:02 AM
pwrtripls1's Avatar
Cams for these things are extremely expensive as far as I've seen. You may get 30whp, but at a big cost. From what I've heard though they drive nice and spool great. I have no personal experience with them though.
How much power will the 370's support? You need around 500hp crank to get over 400whp. Will they make that much more?
Old Dec 2, 2008 | 09:59 PM
i dont honestly know right now 276/665 with the set up in my sig,i did add more timin and ground off the foot on the afc and turned the fuel boost screw in more and id like to go to the dyno here soon,if those wont suport it then what will
07_Ram
Mar 19, 2012 02:23 PM
12valve
Aug 12, 2006 09:33 AM
Mopar1973man
Oct 14, 2005 08:19 AM
andyr354
Feb 2, 2005 05:29 PM
tanderson2002us
Oct 2, 2003 09:25 PM
