master cylinder plumbing
hey guys
stupid question. does the front reservoir of the master cylinder go to the front brake lines and the rear larger reservoir to the rear brakes or is it the other way around? thanks |
Originally Posted by oilcan64
(Post 3199834)
hey guys
thanks mark, does this still apply when i change the rear to disc?
(Post 3199839)
haha awesome! thanks
Originally Posted by maybe368
(Post 3199841)
Yes, I just hooked up the calipers to the existing lines. You are going to love the disks. I have had exactly zero issues with my brakes since I converted them, after being tortured by them for a few years...Mark
Do you have an E-brake ? IF so, how is it set up? please don't tell me you found an old rock you stick in front of the tire....:o |
Originally Posted by NJTman
(Post 3199872)
Has anyone ever tried to mount a parking brake to the pinion?
Lot of heavy equipment use something like this. http://tsmmfg.com/4070.htm Jim |
Originally Posted by Jim Lane
(Post 3200029)
(Post 3200029)
Lot of heavy equipment use something like this. http://tsmmfg.com/4070.htm Jim PINION MOUNTED PARKING BRAKE (Not an Emergency Brake) Not recommended for trucks (Will not hold good and affects ground clearance) http://tsmmfg.com/pinionmountedpb.html Can someone tell me what it's for if it doesn't work ??? My Fuso has a driveshaft parking brake. It's absolutely worthless. It cannot hold the truck at all, and it has been that way since day one. It's mounted up at the trans and resembles a brake drum. I'm sure that's what is inside there. Absolutely worthless.. |
(Post 3200883)
