Lugg nuts
Lugg nuts
I am trying to put on a set of stock aluminum wheels from a 2001 3/4 ton truck on my 91 I'm assuming the bolt pattern is the same but my question is the lugg nuts because I want to use the factory center caps and they are held on by the ring on the lugg nuts. The lugg nuts from the 01 are 5/16 I think but the ones on the 91 are 1/2 and I was woundering if anyone has found a set that has the ring for the center-caps and is 1/2.
From: Lingleville TX but active duty Air Force all over the world currently
I did this also.....you need some special lug nuts. They ended up costing me about 40 bucks....check the sticky, there is a thread in there with a NAPA p/n that will hook you up. I googled the NAPA p/n and found places on the internet selling them cheaper.
http://www.dmauto.net/web/dmauto/Cat...fg/BK/6411549/
They gave me a mil discount......and these work perfect.
admin
Jan 19, 2003 08:35 AM
