Lug torque
Old Apr 2, 2016 | 07:50 PM
Jim Lane's Avatar
Lug torque
I am going to replace my front brake pads today,
what is the torque on the flanged lug used on a steel dually rim.
Also is this with the:
threads lubricated?
flange face lubricated?
Thanks
Old Apr 2, 2016 | 10:58 PM
jimbo486's Avatar
I believe it's 300ft. lbs.
Old Apr 2, 2016 | 10:59 PM
j_martin's Avatar
After lug centering the wheel with 2 90° cone nuts, torque 6 to 50 ft lbs. Remove cone nuts. Torque the other 2 to 50 ft lbs. Then in a cross pattern torque them all to 300 - 350 ft lbs. Spec. is dry. I use a little no-seize on the threads and torque to 300. The flange must be dry.
Old Apr 3, 2016 | 02:47 AM
Jim Lane's Avatar
Thanks guys,
I knew it was somewhere between 300-350/pounds but I I had to think about the flange being dry or not.
What do you use to torque yours with, a 4-foot breaker bar and a calibrated foot?
I used to use one to remove Budd wheels on transit coaches in the field, it was 6' long had a 6' cheater pipe and usually took another guy to help you, after the first 3-4 lugs you were usually exhausted.
Jim
Old Apr 3, 2016 | 08:20 AM
j_martin's Avatar
Originally Posted by Jim Lane
Thanks guys,
Jim
2 foot bar and my total weight on one foot. Remember those Budd Wheels. What did you do if the outside nut froze to the inside one?
Old Apr 3, 2016 | 10:13 AM
jimbo486's Avatar
3/4" Harbor Freight torque wrench with a 36" handle. I haven't needed to go that high on mine though since I have the Alcoa's and 2-piece flanged lug nuts.
Firstgenfanatic
May 14, 2008 06:17 PM
dieselJon
Mar 6, 2008 04:58 PM
Trebor
Sep 14, 2006 04:52 PM
John H
Jun 2, 2004 10:08 PM
BiggRigg600
May 24, 2004 01:23 PM
