To lube or not to lube plastic clutch fork Pivot
And with what?
Good day, M. McKnittle:
I have purchased a few from Quad4x4 over the years and it looks like they just include Ultra Caliper Lube as the pivot lube. QK6007 CLUTCH PIVOT BALL KIT in Dodge Kits |
Thanks Nick.
Is OEM plastic or steel?
Although you need some lubrication grease breaks down most plastics. What does the FSM reccomend? Jim |
Pretty sure OEM is steel, per Quad 4x4 and every stock original clutch setup I've pulled.
The upgrade would be the plastic one. I haven't noticed a difference between the two in the short run though. |
