Lower Axle U-Bolt Plates
Old 10-12-2018, 08:59 PM
mhuppertz's Avatar
Liked 60 Times in 29 Posts
Been looking for Lower Rear Axle U-Bolt Plates so I can fab up my traction bar mounts but I can't find them anywhere.
Anyone know of a source for these? Also I will need new u-bolts and can't find those either.
I suck at this game!
Thanks,
Mark
mhuppertz is online now
Old 10-12-2018, 09:29 PM
Liked 1,205 Times in 828 Posts
Oliver???
NJTman is offline
Old 10-12-2018, 10:06 PM
Liked 1,124 Times in 718 Posts
T-man is correct. I have spare u bolt axle "saddle" mounts here at the shop.
The u bolts... Napa or the like, should be able to help you with, if not a local spring shop should be able to bend your up a set.
I have a semi local to me spring / suspension shop that can bend me up U-bolts of any size and diameter in short order.
oliver foster is offline
Old 10-13-2018, 07:01 AM
I would definitely use the spring shop. Best value for the buck, American made, helping the local economy, and brand new, unused u bolts.
I don't reuse U Bolts, unless it's for a temporary, short lived timeframe..
NJTman is offline
Old 10-13-2018, 01:36 PM
u2slow's Avatar
Liked 83 Times in 66 Posts
Rockauto has u-bolts.... it's my go-to unless I need something special or odd.
Other lower ubolt saddles can be used.... I welded a stud to 2ndgen ones for shocks. No big deal. Also seen an example where a shock stud was added to the lift block 'ear'. YMMV.
u2slow is offline
Old 10-13-2018, 02:27 PM
Liked 860 Times in 561 Posts
I second a spring/suspension shop....ones I have used I just tell them what I have and they walk out and grab some bars with the threaded end, toss them in the press and bend them up in seconds. FYI the saddle plates are different between D60 and D70 rear ends.
thrashingcows is offline
Old 10-13-2018, 02:45 PM
u2slow's Avatar
Yes, the saddle plates vary depending on the axle tube size. 9.25" and D60 are 3", D70 is 3.5".
u2slow is offline
Old 10-13-2018, 03:04 PM
Dana 60, Dana 70 and Dana 80 axle saddles are all different
The Dana 80s come in three styles. A Cab and Chassis dually style, Dana 80 standard dually pick up saddle style AND a SRW Dana 80 style.
The local spring shop that makes custom length U bolts makes them in a few minutes while you wait and in all sorts of custom lengths and rod diameters. That and they are also about half the price of getting them from Napa.
I had to order them from the local spring shop for my Dana 80 axle install on my white crew cab as Napa doesn't carry anything that long or rugged.
The following 2 users liked this post by oliver foster:
death row dave (10-14-2018), thrashingcows (10-14-2018)
03CTDCO
06-11-2011 06:08 AM
xb9rumble
06-28-2009 08:50 AM
smog2001
08-10-2007 09:32 AM
broncobilly
04-18-2007 07:45 PM
rockittboy
01-14-2006 10:23 AM
Quick Reply: Lower Axle U-Bolt Plates
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
