Low oil pressure at idle?
Hey, I just went and looked at a 92 D350 that is for sale. It looked pretty good inside and out. I decided to take it down the road so I started it up. The oil level was good prior to starting and the oil pressure came up to normal. I drove it for about 10 minutes and then came to a stop at a light. I noticed that the oil pressure dropped down to the first mark off of L. When I pulled off, the pressure came back up. Is this common? My 91 W250 doesn't fluctuate like that.
Also, I noticed that the odometer did not work even though the cruise, OD, and speedometer did. What would cause this? This truck ran a lot cooler than mine. The temp gauge never came into the normal range. Mine usually runs about the middle at 60 mph.
Thanks,
Chris
Thanks,
Chris
Both my 93s run at idle at the 1/4 up and at speed at the 3/4 up on the oil, neither ever run at 1/2 on the temp always just off the first 1/4 mark unless loaded on a 100 degree day pulling a grade. hope this helps
teh oil sender went bad in my truck shortly after buying it. It had always read lower than I thought it should, eventually got to where the light came on at idle. Put a mech. gauge on and the motor was just fine.
I have rarely been over the 1/4 mark on the temp gauge, even towing uphill in the summer.
I am not sure but I have heard that oil should be at least 10 psi per 1000 rpm. That is the minimal it should be and anything above should be ok. After a hot run down the track, mine has idled down to 40 - 50 psi (during summer) and have seen it climb to 75 - 80 during fast runs down the track. Upon startup (cold) I have seen it go right up to 85 - 100 psi on those cold mornings. Drive real easy and it settles back down to normal after a few miles. I have 215,000 miles on the truck. As for the stock gauge, usually around the 3rd line going down the road.
my 93 does, more or less, the same thing. i took it to a cummins shop for a look. they put one of their oil pressure gages on it and it read 25-30 lbs oil pressure at idle and it jumped up to 60 as soon as he hit the throttle. he said no worries.
jeremiah
jeremiah
Power Ram 250 C
Feb 20, 2007 11:08 AM
tyssniffen
Jun 30, 2006 09:44 PM
HappyCamper
Apr 23, 2006 05:28 PM
tyssniffen
Feb 17, 2006 10:26 AM
zrx1100mag
Apr 28, 2003 07:28 PM
