Losing Power after 3200 Spring Install
Old Jan 21, 2008 | 09:35 PM
Murphy85's Avatar
I got the 3200 rpm spring in and everything went good and the truck ran perfectly for the first day. Now the boost has dropped to 20psi and it lost power all the way through the rpm range. I did have the throttle lever off after the first install but I am pretty I put it back on the same way. Any idea on what this could be? I am out of ideas.
Old Jan 22, 2008 | 07:08 AM
G1625S's Avatar
Fuel screw locknut came loose? Nut for throttle linkage didn't pull the shaft up through the splines and now it's loosened? Recently, coinidentally clogged fuel filter starving the IP?
Old Jan 22, 2008 | 01:44 PM
Murphy85's Avatar
the fuel screw locknut is tight and I will check the throttle shaft that could be it. I just replaced the fuel filter and I know the symptoms of a clogged one. Any more ideas?
Old Jan 22, 2008 | 05:21 PM
DLittle's Avatar
I had to reindex my throttle shaft after my install. I put it back to when it was before install and I had no power at all. I had to go all the way up and down on the marks on the shaft to get all my power back.
hounddogks76
Aug 31, 2012 09:22 AM
92smokin blacky
Oct 3, 2010 07:21 AM
BurrisWill
Jan 25, 2009 08:23 PM
"B" SCARED
Jun 21, 2008 11:18 PM
xtremexj
Sep 19, 2006 05:28 PM
