lights flicker while Idleing
Old Dec 7, 2008 | 08:27 PM
wise_cummins's Avatar
I just installed a new alternator on my 90 dodge. The lights are still flickering while idleing. Any Ideas??? Also looking for the hard to find vertical flow radiator anyone know where I can get one aftermarket.
Old Dec 7, 2008 | 08:45 PM
TJE's Avatar
TJE
Can't help with the rad. My lights did the same it was a ground...ran a wire from the neg. terminal to the body solved the problem. Good luck, Tony
Old Dec 7, 2008 | 08:47 PM
Richie O's Avatar
366 Spring Chicken
Thats where I would start.
Old Dec 7, 2008 | 09:57 PM
schamran's Avatar
They flicker, or get dim for periods of time? In the cold, your intake heater will cycle, and the draw will cause the lights to dim, like a hair drier in your bathroom. Not sure if this is what you are experiencing, but if it is, it's normal. Hope this helps.
Old Dec 7, 2008 | 10:08 PM
800rmk's Avatar
We had the same problem on my dads' 89. We ran a ground wire from the voltage regulator to the fender well. I know they are famous for the external regulator not grounding properly, causing problems.
Old Dec 7, 2008 | 10:19 PM
rebal's Avatar
A cheepo voltage reg will also cause flicker I bought the napa $45 not the $13 one and its stopped on my 90
Old Dec 8, 2008 | 03:59 AM
keith1992's Avatar
Battery could be on its last leg.
Old Dec 8, 2008 | 11:55 AM
90firstgen's Avatar
Here's a tip I found useful, buy Mopar voltage regulators. The "good" aftermarket ones always lasted me about 1-2 years if I was lucky. Some lasted a few months. I paid about the same amount of money for a Mopar one as I did an aftermarket one and I'm going on about 2 years with it so far and its good as new still. I still carry an extra in the glovebox though
Old Dec 8, 2008 | 05:27 PM
BearKiller's Avatar
Use the MOPAR regulator in my "sig" and no more flickering lights.
dieseldel
Aug 26, 2006 10:27 PM
Chrisf
Aug 21, 2006 08:06 PM
csramsey640
Jun 20, 2006 09:49 PM
csramsey640
Mar 29, 2006 06:15 PM
Extreme Diesel
Oct 23, 2002 10:23 PM
