Lift pump PSI
Lift pump PSI
I just had my 01 2500 in for an oil change and general check up today. The mechanic questioned my fuel pressure (I have an isopro gauge) which is at 7-8 psi at idle. No one in the shop thought that the psi should be that low.
I'm on my 3rd lift pump; the last one has lasted 70,000 miles since they put it in the fuel tank instead of under the hood. This was maybe 5-6 years ago. It was installed by a Dodge dealership and they told me that I would notice that my pressure would be only about half what it was before when the lift pump was under the hood. They were correct as I immediately saw 7-8 psi at idle and sometimes down to 4 psi when towing a fifth wheel.
It seems that the Dodge dealership that installed this last lift pump said that there had been a technical service bulletin about the old lift pumps and that they should now be installed in the fuel tank.
Question. Was the dealership that installed the pump correct that the pressure SHOULD be that low, or are the current mechanics correct that it should NOT be that low? The truck runs fine since the installation, but should I be worried that the injection pump is not getting lubbed? I'm NOT very mechanically inclined, therefore in the dark about this. Thanks.
That low would worry me. especially knowing that low lift pressure can kill the injection pump.
I have a Air Dog lift pump on my '01
20 PSI at idle
If it gets below 15-16 PSI at WOT I know it is getting time to change my fuel filter.
With a fresh filter I can't get it below 17 PSI no matter what I tow or how I drive it.
20 PSI at idle
38 Cigarette
16
08-28-2015 11:27 PM
nrussell
07-23-2008 08:58 PM
Tommy93w350
08-07-2007 12:15 PM
Dave88LX
15
09-04-2006 09:30 PM
ckennedy
09-29-2004 05:06 PM
