Lift pump gaskets...
Old Jun 14, 2010 | 04:17 PM
Not sure if this is common knowledge or not, but the gasket between the pump and block, be it the original style diaphragm pump, or the piston pump, is the same gasket used on mopar gas fuel pumps from the 50's on up into the 90's on everything from slant sixes, small blocks and big blocks.
I checked my garbage "New" lift pump on an old small block timing case today, fit perfect, bolts line up and everything.
Old Jun 14, 2010 | 04:19 PM
Small block chevy fuel pump gaskets are the same as well.
Old Jun 14, 2010 | 07:59 PM
Well there you go, another source.
Old Jun 15, 2010 | 07:48 AM
ZSkibo's Avatar
Where'd you hear that Brandon? Hahaha...
Txwelder
Nov 26, 2025 01:53 AM
SU-Rancher
Mar 6, 2011 01:23 PM
Txwelder
May 19, 2005 06:10 PM
srowen
Jun 27, 2003 06:44 PM
mymaur
Dec 23, 2002 08:28 AM
