Leveling a '92 - ???
Old 04-10-2003, 05:45 PM
ouchman's Avatar
What can I do to raise the front end of my truck to be more level with the rear? I rarely carry real heavy loads so leveling should be okay, right? If I could lift it 2&quot; or so I think that would do it.<br><br>Thanks
Old 04-10-2003, 07:28 PM
Monty's Avatar
Re:Leveling a '92 - ???
First off, is your truck a 2wd or a 4wd? If it is a 2wd, you will probably notice that the drivers side sags lower than the passenger side. Mine sat real low when I got it. A pair of MOOG heavy duty springs fixed the problem. It now sets level with the rears. If you do a search in this forum for MOOG part numbers, you will find the list that I compiled.
Old 04-10-2003, 07:49 PM
ouchman's Avatar
I't a 2wd, auto trans.
Old 04-14-2003, 09:04 AM
Nuttymopar's Avatar
My 4wd sat the same way, about 2&quot; lower it seemed. Skyjacker sells front lifts for 4wd. I would recommend new springs since yours is only 2wd. I actually ended up putting 2&quot; blocks on my front and 1&quot; block on the rear to level it out nicely. Some day, new springs and bushing all around, that should make it ride smoother. Blocks will make the ride a little harsher.
Old 04-19-2003, 11:02 AM
scottben's Avatar
I would like to introduce myself, I looked for a forum section intended for introductions but didn't see one. I have a question regarding the topic in this thread anyway.<br><br> My name is Scott Benson. I live in Cedar Rapids, Iowa. I ordered a new D-350 CTD w/DRW's from a local dealer back in 1988 and I've owned it ever since. It has turned out to be one of the best machines I've ever owned.<br><br> A few years ago I invested ~$3K in a paint job. I had all of the body molding removed and the entire truck painted aquamarine blue. It turned out beautiful. I'm very proud of my truck. <br><br> I too would like to raise the front end a bit. I would like to install the Moog springs that Monty described in this thread but when I attempted to search for the part no. I was unsuccessful. I would appreciate some help in finding out the number(s).<br><br>Thank you,<br>
Old 04-19-2003, 11:09 AM
Monty's Avatar
It looks like the older threads have been deleted. I have it written down in my truck, I will post the part number tonight.
Old 04-20-2003, 12:52 AM
scottben's Avatar
I was reading many of the varied topics in this subsection and I stumbled onto the part numbers I was seeking way back on page eighteen (I think).<br><br> Moog Coil Spring<br> Heavy Duty: 7226<br> Super Heavy Duty: 7226S<br><br> Thank you for replying to my original post so quickly. You have a first-rate forum. I plan to visit often. <br><br>
dodgeboy59td
26
12-31-2002 12:05 AM
UTAH
32
12-11-2002 11:47 AM
Fishin2Deep4U
12-10-2002 07:34 PM
j
17
11-10-2002 07:57 PM
Quick Reply: Leveling a '92 - ???
