leaking injector
Old Jul 20, 2009 | 08:04 AM
blue 1st gen's Avatar
leaking injector
Maybe some one here could answer my question.I replaced my lift pump and started the truck to bleed the injectors ,everything went fine until it started leaking fuel around the base of the injector,5th one back (it bubble's around the body and the big nut) so before i go crazy ,What do i do? any reply's would be very helpful thanks
Old Jul 20, 2009 | 05:00 PM
Try tightening the big nut. If it doesn't stop, you'll have to pull the injector and replace the copper washer underneath.
Old Jul 21, 2009 | 07:01 AM
Thanks for the reply,I ended up doing that then all the others started to do the same thing ,but the 3rd one just would not seal so i ended up pulling it out and cleaning it,while i was cleaning the hold down nut there was a seal on top of it that just disapeared but i put it back together and it sealed , but the truck still has a hard time starting ,I bleed the injectors(maybe im doing it wrong idk) I bleed the filter while it was running , the truck always started quickly but know it cranks like it's out of fuel and stumbles while it's starting,any thoughts ?
Old Jul 21, 2009 | 07:05 AM
The seal on top just keeps crud and water from rusting the nut to the injector. I'd replace it but it's OK to run for a while without it.
Sounds like you are getting air in the fuel system. On an '89 in NY I'd be taking a close look at the fuel lines from the tank. Another common leak point is the fuel heater gasket (fuel heater is the thing between the filter and the engine, there's a gasket on top of it). Also the lift pump can leak.
Old Jul 21, 2009 | 07:20 AM
The truck was a frame off resto ,it has all new ,pickup,tank ,1/2 plastic lines,and i deleted the fuel heater two yrys ago ,and just replaced the lift pump two weeks ago,but I noticed when i pulled the supply line to the lift pump there was no fuel ,but after it runs and i crack the filter bleeder there is pressure behind it even after it sat over night maybe im doing something wrong idk
Old Jul 21, 2009 | 05:19 PM
Is the tank vented?
Old Jul 21, 2009 | 05:55 PM
Im pretty sure it is ,I never noticed vacuum behind the gas cap,When i got home tonight i went to start it and it cranked like it was out of fuel and stumbled starting after i was giving it about 1/4 to 1/2 throttle,once it started it took a few seconds to clear up ,the smoke was gray and black like it was flooded,the truck only started doing this in the last two months,so i replaced the lift pump ,I bled the injectors and it seemed fine until it stalled while i was driving at 40mph one day and wouldn't start (i had it towed) got home cracked all the injectors turned it over until fuel came out snuged up the injectors and it started right up ,but now it just dose not want to start
lilsuzuki4x4
Sep 1, 2011 01:50 AM
Jambbii
Nov 5, 2004 10:59 AM
berner
Mar 7, 2004 09:02 AM
bwat4
Feb 6, 2004 09:32 AM
yomitch
Apr 21, 2003 06:28 PM
