Leaf Spring Removal
Old Dec 30, 2007 | 02:14 PM
mawghauler's Avatar
Leaf Spring Removal
The left rear leaf on my W250 has a bolt that looks as though it will be tough to remove on the front spring eye due to the fuel tank being in the way. Anyway around not removing the fuel tank?
Old Dec 30, 2007 | 02:21 PM
Montana2x2's Avatar
If you loosen the rear tank strap you can move the tank enough to get your hand in. That's how I did mine.
Old Dec 30, 2007 | 04:14 PM
mawghauler's Avatar
Thanks Montana
Old Dec 30, 2007 | 09:22 PM
feveree40's Avatar
Your best bet will probably be to cut the bolt out with a thin cutting wheel on an angle grinder. Even if you get the nuts off the spring eye bolts, they are usually frozen in there pretty good. I cut mine off (stuck the cutting wheel between the leaf and the hanger) then got the bolt out when I could get to it easier.
97catintenn
May 28, 2010 08:29 PM
goodeyesniper75
21
Aug 28, 2007 10:21 AM
Joe T
16
Jun 12, 2007 12:11 AM
gofastman
Mar 20, 2003 11:38 AM
