king pins
king pins
iv been working on my king pin bushing replacment kit after work these past 2 days but now i think i have missed something or add one more seal then i needed, the kit comes with springs, bushings, axle shaft seals, and everything you need, but i saw on top of the king pin bolt there was a seal that looked exactly like i had in my kit so i put it on and continued on my way and installed it all and bolted everything up then i noticed on my axle shaft is the exact same seal, now i dont know if the seal had to be around the king pin bolt?, i will list what i installed from top to bottom, and tell me if i added more or missed something
top:king pin bushing, spring, spring washer that rests on bushing, gasket, rubber gasket around base of king pin.
bottom:rubber seal that goes around metal cap that goes in first before the bearing race, then bearing, and then a aluminum seal with rubber piece, then cap.
and in the king pin kit i got a smaller o-ring, whats that for?
thanks for anyhelp i can get ,
Gregg
Gregg
please can some one help me out here?! my truck sitting in my driveway on blocks with me standing dumbfounded beside it any help would be awsome
does this help?
http://pirate4x4.com/tech/billavista...pin/index.html
