keyed power starting issue
Old Mar 25, 2013 | 06:46 PM
bryson711's Avatar
ok, so im pulling my hair out trying to figure this out, i have searched and read through what i could find. when i try to start my truck i turn the key and everything works fine power wise but the truck will not turn over, i am not getting the signal to the small wire running to the starter. i know its not the starter cause i can turn the key on and jump the starter and it starts right up. im kinda thinking towards maybe a fuseable link just not sure which one to check? or if there could be another problem? with the key on everything works completely normal and the grid heater is cycling like normal.
Old Mar 25, 2013 | 07:16 PM
simplysmn's Avatar
It's the Relay on fenderwell Bud replace it with a reg Bosch relay it should fire right up that's what was wrong with mine I could jump the wires and it would run but not from key changed relay thing's r Fine .
Old Mar 25, 2013 | 07:24 PM
bryson711's Avatar
man i wish everything was that easy to fix! i just went out and swapped 2 of the relays on the fender and it fired right up! im guessing the only place you can get a bosch relay is the dealer? part number by chance?
Old Mar 26, 2013 | 08:47 AM
Smokin$$away's Avatar
bryson711 I had bad luck this morning on my 92. Turned on key and nothing. I have headlights, taillights, well everything but blinkers, no dash lights no buzzer and it's won't turn over. Mmmm maybe my relay went out. Any ideas anyone before I start on it? Thanks!!
Old Mar 26, 2013 | 09:16 AM
j_martin's Avatar
That one's going to be a fuse or fusible link.
Simply's solution for bryson was a SWAG (Scientific Wild A*** Guess). Statistically the relay is most often the problem, but not always. Usually you have to actually get into the diagrams and understand them.
Old Mar 26, 2013 | 09:57 AM
Thanks j_Martin I have the test light in hand but it's 37* out sooo I'll wait a bit before I start. I'm old with a busted up wore out body that doesn't like the cold. Thanks for the input!!
Old Mar 26, 2013 | 10:39 AM
simplysmn's Avatar
It was from Having the same problem when I fired mine up replaced the relay and it ran so I guess it's Been there Done that .
and the reason I say just a reg Bosch relay is there easy to get I carry a few spares in truck .As for relay's any part's house has them on the shelf or next trip to a Pick a part they fit nice in the Pocket
Old Mar 26, 2013 | 12:14 PM
bryson711's Avatar
I was able to get one at car quest today, I actually bought 2. Never hurts to have a spare. I thought for sure I would be trying to fine an electrical grimlen! Got lucky I guess:thumbup:
Sent from my DROID4 using Tapatalk 2
Old Mar 26, 2013 | 01:26 PM
Fuses all good! Changed out all relays and nothing!! What next?? Wiring I don't like. BTW I borrowed a service manual what page shows the fuse box/block showing what fuse is what?? I've looked but overlooked!!
Old Mar 26, 2013 | 03:00 PM
Chrisreyn's Avatar
Smoking, JMartinwas right, look to the fusible links on the drivers side fender well under the hood hinge
I believe the ignition circuit is the Red/Black trace.
Might be a good time to go ahead and replace all if them with in-line fuses if the apropriate size
Old Mar 26, 2013 | 07:09 PM
j_martin's Avatar
There's 2 fusible links that go to the ignition switch, both 20G, 1 circuit color is black, the other red. The red one drives the engine stuff, as well as the turn signals etc. The black one runs the power windows and the heater. In the 1993 manual, the fusible links are on page 8W42-42, and the ignition switch on 8W-51.
If the red wire to the ignition switch has power, the switch itself is bad.
Old Mar 28, 2013 | 04:23 AM
KRB's Avatar
KRB
Look for the "duckfoot" on the fender well with one big loom going in and a bunch of little wires coming out. Man I hate fusable links...
Old Mar 28, 2013 | 10:35 AM
Grrrr I had it all going everything working ect. Drove around yesterday about maybe 100 miles and all looking/working great. Wife goes out this morning to move the ole ride and the battery is stone cold dead. Calls me and says now what? Told her to turn on headlights and nothing. Puts charger on it and sure enough dead, new battery 5 days ago! I can feel the aggravation some go thru on these ole trucks. Ding dang more work to be done when I get back home!! I'll get it right someday! May have to wire it to be a completely a manually free truck! Oh well I won't be bored when I get home!!
Old Apr 4, 2013 | 10:38 AM
70chall440's Avatar
I had the same problem, I changed the ignition switch (no joy), changed the relay (no joy), changed the Neutral safety switch and that fixed it.
now it is on to the TPS, cruise and horn as well as the idle...
Bluedeviltorque
Apr 13, 2017 02:45 AM
Bad Ramer Jamer
16
Dec 29, 2005 01:21 AM
chaos24valve
Oct 25, 2005 08:03 AM
linetrash75
Jan 20, 2005 11:23 PM
Journier
Dec 18, 2004 08:26 PM
