KDP Question,...
Old Jan 10, 2008 | 02:26 PM
DarrinGT's Avatar
KDP Question,...
I am killing my KDP while it is on the Motor stand. It is a Cummins Reman with 20K on it. It was bought new in 2000.
The problem is that where the dowl pin is, there is a ridge. It is not flat like what shows in the instructions in the KDP kit that I purchased.
Has anyone run into this? Do I put some washers behind the bolt to bring the tab out 1.4" or so?
Let me know what you think,..?
Old Jan 10, 2008 | 02:28 PM
DarrinGT's Avatar
Here are some pics of the motor:
Old Jan 10, 2008 | 02:47 PM
Chrisreyn's Avatar
Darin, I THINK that the ones with a ridge are where folks have been using the coat hanger wire tabs instead of the kit tabs.
I bet WANNA could tell ya if you ask him...
Old Jan 10, 2008 | 02:48 PM
JD730's Avatar
Take a center pump and peen the hole in around the dowel pin. The tab is really meant for the p-pump front covers.
Old Jan 10, 2008 | 02:49 PM
ofcmarc's Avatar
I believe you are right Chris
Old Jan 10, 2008 | 02:54 PM
dieselJon's Avatar
Yep, the KDP kit you have is for a 2nd Gen 12 valve. They are flat while ours have a step.
And while you are in there, loc-tite all the case bolts as mine were finger loose and the KDP was still in deep. The case bolts are more of a problem with 1st Gen 12v the the KDP.
Old Jan 10, 2008 | 03:00 PM
Chrisreyn's Avatar
actually , thinking about it, if that is a 2000 motor, I am not sure he needs to worry about the KDP anyways.. but since its open, if you wanted to tab it, it looks like you could use a coat hanger wire tab thru the slot visible between the bolt and the KDP....
Old Jan 10, 2008 | 04:16 PM
DarrinGT's Avatar
Thanks for the input! Looks like a Coat hanger it is!
Anyne need to buy a KDP kit,...?
Old Jan 11, 2008 | 09:13 AM
Falcon1's Avatar
The kit I got had the tab bent to fit over the ridge
sootnsmoke
Jan 5, 2012 08:55 PM
Smokin96_12v
Oct 12, 2009 07:39 AM
Deereguy
Feb 12, 2004 06:44 PM
turfquip
Nov 12, 2003 10:49 AM
1320
Jul 6, 2003 03:41 PM
