kDP
Old Dec 30, 2010 | 12:15 AM
Thiss's Avatar
kDP
The write up in the sticky on killing the kdp is not working. I didn't buy a kit. Just a gasket set. Should I make a tab, or just use a punch a dimple the whole?
Old Dec 30, 2010 | 01:00 AM
dodgetrucker75's Avatar
if its resessed below the cover, just peen the hole over, if its out and cant be punched back in, just bend your own tab out of a piece of tin, just dont forget to pull and lock tight every bolt you can get to in there
Old Dec 30, 2010 | 07:18 AM
Exekiel69's Avatar
I wish I could find the pic but basically what I did was drill the case above the pin, tap it and drive a SS bolt all the way against the KDP if it try to come off it will have a bolt pushing it IN. The tab can also come off, this is a bolt and cannot go sideways.
Old Dec 30, 2010 | 07:24 AM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
i bent up a piece of coat hanger. i tried to peen the case but it just kept breaking. must have been some of that Chinese aluminum.
Old Dec 30, 2010 | 07:25 AM
Onemoparnut's Avatar
I just peened the aluminum it don't take much just enough to distort the hole so it can't fall out.
Old Dec 30, 2010 | 08:55 AM
Thiss's Avatar
KDP hasn't budged a bit! I will peen hole. Man this forum with the new Google search it is like a shop manual. Especially when i have a pc lab right by the shop.
Old Dec 30, 2010 | 09:03 AM
Thiss's Avatar
Gasket is in great shape, do I dare reuse?
Old Dec 30, 2010 | 09:04 AM
I usually just use a little gasket sealer and put it right back on.
Old Dec 30, 2010 | 09:55 AM
MARF75's Avatar
I just did mine Tuesday. There is absolutely no way that tab can move unless the bolt holding it comes all the way out and at that point it wouldn't be the dowel pin you would have to worry about! In fact,I had a hard time getting the bolt in with tab because the tab fit the outer contour of the case so tightly.
102,ooo miles and the pin hadn't budged
Old Dec 30, 2010 | 01:34 PM
Thiss's Avatar
bought kit, do i need to use adhessive on a felpro gasket?
Old Dec 30, 2010 | 10:44 PM
Thiss's Avatar
KDP Killed. Heads up though admins; our write up link in the sticky is dead. It is probably time for one of our more savy members members to do a one and host is on this site.
sootnsmoke
Jan 5, 2012 08:55 PM
Smokin96_12v
Oct 12, 2009 07:39 AM
SjLingenfelter
Jul 19, 2003 05:14 PM
WalkingHorse77
Mar 19, 2003 12:27 PM
gofastman
Mar 19, 2003 10:29 AM
