kdp?
Old Nov 25, 2008 | 09:03 PM
DU.DP.'s Avatar
kdp?
i've been doing a lot of reading up on it and was wondering if you have to do it to the 1st gens? im assuming you do but a lot of the guys who ask on the DTR site have 2nd gens TIA david
Old Nov 25, 2008 | 09:42 PM
peobryant's Avatar
Its not really a problem in 1st gens as much as 2nd gens, but it doesn't hurt to do it just in case.
Old Nov 25, 2008 | 09:44 PM
Bob Beauchaine's Avatar
Yes you will have to do it to your first gen. The best way is to pull the front cover and make your own tab for the KDP. That way you can also do the 5 internal bolts holding the front cover to the block - one of which will hold the tab in place. Four bolts can be done by removing them, cleaning, locktiting and reinstalling them. The 5th is behind the PS/Vacuum pump drive gear. You will need to custom bend a wrench to loosen this one - it will not come all of the way out without removing the drive gear. Loosen it up as far as you can then clean it and use the weaping locktite.
Bob
PS
I've seen the damage one of these bolts can do - cam broken into 3 pieces - 6 bent push rods. Luckily that was all the damage to the engine - could have grenaded the engine.
Old Nov 25, 2008 | 10:22 PM
DU.DP.'s Avatar
alright thanks for the info. i should do it soon theres 234k miles on the truck. im not sure if the previous 2 owners had it done. something i should look into. thanks for the help
Old Nov 26, 2008 | 12:24 AM
gozapper's Avatar
What is weaping loctite?
Thanks Tom
Old Nov 26, 2008 | 06:32 AM
Thanks Tom
Lotite 209 aka Green. It wicks into threads. Cool stuff - you can dab it on exposed threads of an already tight fastener and it will wick into the connection to lock it up.
http://www.loctiteproducts.com/produ...id=48&plid=695
sootnsmoke
Jan 5, 2012 08:55 PM
Smokin96_12v
Oct 12, 2009 07:39 AM
SjLingenfelter
Jul 19, 2003 05:14 PM
WalkingHorse77
Mar 19, 2003 12:27 PM
gofastman
Mar 19, 2003 10:29 AM
