ive got a problem
I think i popped a fuse in my truck where are they? the radio, the door light, the little message board thing, and the cargo light, all do not work but the headlights and the dash lights work can some body point me towards something
On the drivers side inner fender there is a white connector located directly below the hood spring, between the grid heater relays and the hood spring. It has a tendency to corrode. Give me a few minutes to attach a pic from photobucket. I attached a jumper lead to point it out.....
check the wires feeding into your fuse block under the steering column. Mine for my interior lights broke free and it was no longer making contact with fuse. The plastic that holds the spade type connector broke. The fuse appeared fine but did not have lights.
