It's finally on the road!
Your bumper looks like a Warn Enforcer facebar with custom ends and top plates. Original bumpers came with black plastic end caps and black steel diamond plate top plates. They were only available for a few years in the 90's. Your pic gives me a few ideas on how to make new end caps to replace the cracked ones on mine. And the fenders can be removed separately from the core support.
Truck looks great ....Congrats on getting it back on the road. If you dig through my build thread you can see what I did to combat the cowl cracks.....I used that heavy flexible metal banding with holes in it every inch or so, easy to conform to the contours and then lots of areas to spot weld....I think it worked out really well.
Post # 486....
https://www.dieseltruckresource.com/...305923/page33/
Post # 486....
That's a great use for pipe hanger. I use it all the time and I always have some in my tool box.
Edwin
thrashingcows (05-01-2018)
Post # 486....
Post # 486....
I have done the same with cut out strips of old fender sheetmetal. Used the exact same way.
I was being a nice guy last month and was helping a friend move from downtown Denver. The truck died in the middle of the road. After about a 6 hour venture between towing it to a parking lot, fixing the fuseable link, unloading it, driving home, and fixing it a few times along the way I finally made it home. Frustrated I just disconnected the battery and left it to decide what I wanted to do. Combed through the wonderful wiki on here and got a game plan on fixing it. Ordered the fuse block that has illuminated led's when a fuse is blown, and set out on removing the rest of the fuseable links. I used a 150 amp reset-able circuit breaker for the alternator wire (which I still need to fill with solder and heat shrink which I will do Sunday). After that I just took off all the extra tape, and rancid connectors others have used over the years, and soldered/heat shrunk every connection then re-wrapped the harness and plugged everything into the new fuse block. The fuse block is rated for 100 amps total and has an 80 amp maxi fuse currently protecting it. I will be ordering a 100 amp circuit breaker to replace the fuse, but for now i'm very pleased with how it turned out.
The following 5 users liked this post by Dan70:
Bob L (11-16-2018),
edwinsmith (11-16-2018),
J33p (11-17-2018),
nonrev (11-17-2018),
thrashingcows (11-16-2018)
WOW, that is nice !
where did you purchase the fuse block & Model number ?.
did you have to order the fuses separate ?.
this is something I need to do !
This is the fuse block I am using. In the hand it seems to be built pretty well. Time will tell. The fuses to come separate, but all in all i'm maybe $30 into this repair/fix. The piece of mind knowing that I can replace a fuse on the side of the road instead of dealing with a fuseable link is priceless.
The following 3 users liked this post by Dan70:
I was trying to figure out what that large black connector was on your fender, since I don't have one on my 93 wiring harness, nor have I seen one before on any 1st Gen's....then I looked at your truck listed in your sig.....Ahhh it's a gasser 93!
Some unfortunate things have happpened recently and now i'm going to be moving from here in Denver to Arkansas. about a 14-15 hour drive with a car. So i'm stuck trying to do some last minute things to get the truck as ready as possible. Just dropped the tank last week to get the fuel pump replaced. I underestimated how much gas was left in the tank, it easily had 12-15 gallons left. I cut out the old pump and wired it up to pump what was left into my winter beater. It's soooo nice to have a working fuel guage again. While under the truck I noticed the front u-joint and slip yoke had some play (i've had a driveline vibration for a while now). So I pulled the driveline had a local company put on a new set of splines, yoke, both u-joints and rebalanced. Silky smooth driving now. Going to need to update the trailer wiring before I leave. The current trailer plug is all corroded and nasty. I've got 3 toolboxes and some household stuff to be taking with me. Fingers crossed the ol' girl makes it alright!
thrashingcows (01-18-2019)
What happened in the insurance settlement from the accident? Do you still have a good title or a salvage??
bandit1trucking
02-14-2019 08:16 AM
rustyshakelford
Competition / Pulls / OffRoad
07-04-2007 10:40 AM
