IP Question
Old Jun 16, 2010 | 10:27 PM
Montana2x2's Avatar
Question IP Question
What is the difference between the intercooled and non-intercooled Injector Pumps? Are they interchangable? Thanks.
Old Jun 17, 2010 | 06:06 AM
KD93's Avatar
The only difference between the pumps is the TPS on the auto ones. Otherwise everything else is the same.
Old Jun 17, 2010 | 06:40 AM
The difference between the I/C and Non i/C pumps-
Non i/c pumps have longer delivery valve holders and slightly bigger Deliv. Valves
Non i/c pumps and i/C pumps have a different working KSB.
So if you're putting a Non i/C pump on an I/C truck (which i've done), you must swap the shorter delivery valve holders and valves onto the Non I/C pump or else the I/C fuel lines won't match up to the pump at all, Also swap the KSB off the I/C pump to the non I/C pump.
Coming from someone who has done this.
Old Jun 17, 2010 | 04:21 PM
KD93's Avatar
Oops, wrong again! Thanks for the clarification Brandon, and sorry for the misinformation Montana 2x2.
Old Jun 17, 2010 | 08:32 PM
Montana2x2's Avatar
Thanks guys.
mkeanglorldo56
Nov 4, 2007 12:34 PM
Oval Racer
Jan 26, 2007 02:57 PM
8mpg
May 8, 2006 06:37 PM
donhov
Dec 13, 2005 01:48 PM
