interior question
interior question
hi
anyone ever take thier dash off to replace it with another? currently my interior is red and parts for it are impossible to find and a friend has a complete gray interior and im thinking about changing my entire interior to gray
just curios of how hard it is to remove the entire dash cover? everything else is easy other than that
thanks for all the input
Justin
Justin
That helps me also, working on a wrecked truck where the dash is sprung. Windshield is shattered, so it will be pretty simple I how. The previous owner hit something really hard & wasn't wearing a seat belt.
cool! i plan on removing the windshield anyways. so basically just take the odometer panel thingy off (piece of cake, that wooden lookin piece) then the screws like you said
oh, does the glove box come out with the dash as one piece or is it its own separate unit
oh and id have to put my vin# tag on to
thanks for the help
thanks for the help
I am sure you can find a drwaing but the easiest way is to just start on one side and work your way over should not take you lok=nger then about 20 min's to pull it out sense you have windshield access it's easy as for vin tag just use small pop rivet's and put it back in same spot should not be a problem there is a bracket on pas side under dash by heater system that can be a pain but other then that to swap dash over maybe a few hour's and several Beer's
After all of the rest of the VIN’#’s on the vehicle matched up they would believe you but you might be sitting along the side of the road for a while.
I would have to look but aren’t the rivets covered by the dash pad with only the numbers showing?
This is just a worst-case scenario of course but I would be careful, you can actually buy Rosette Rivets on the Internet for people who restore car, go figure and I think body shops can also get them.
Jim
From memory the rivets have 5 points and are not round. Also note that if the truck has spent most of its life in direct sunlight the plastic dash top becomes very brittle. It will not tolerate very much twisting and will snap like a piece of glass when twisted too far. One indicator of being brittle are small cracks forming.
Vintage Empire
Dec 20, 2005 10:02 AM
rifleman
Mar 28, 2004 02:39 PM
