Intercooler ?s
Old Jun 24, 2006 | 08:27 PM
xtremexj's Avatar
Intercooler ?s
I see a lot of discussion on how to intercool a non-I/C 1st gen Cummins. Has anyone ever considered any of the universal I/C kits for the ricers? You can get a small Greddy (core size 27"x5.5"x2.5") with a piping kit and elbows for $160. I figure you could find a way to mount it behind the front bumper and cut some holes in the bumper to allow the air flow. What do you think of that?
Old Jun 24, 2006 | 08:42 PM
flashgordon's Avatar
the only thing that would bother me is if it would flow with out restriction, and if it would be effecient or as effecient as the stoke one!
Old Jun 24, 2006 | 10:48 PM
jrussell's Avatar
I'm by no means an expert in turbos/intercoolers, but I think a typical ricer with a turbo only runs about 6-8psi of boost. Flash might be right that an IC made for such low psi/flow would be restrictive on our trucks.
Old Jun 26, 2006 | 05:25 PM
xtremexj's Avatar
Just to let you all know, the manufacturer of the intercooler I was referring to e-mailed me back and said that their units are rated for up to 42psi. Just thought you'd want to know.
Old Jun 26, 2006 | 05:35 PM
Sounds good! Did they give any flow numbers?
Old Jun 26, 2006 | 05:37 PM
Not trying to be a pesames, about this idea.....it might work, but there would have to be some stock intercooler volume numbers made at that or some ether psi w/ volume ##that mached or hopfully better then the stock intercooler
if a rice rocket intercooler company could show side by side resolts between stock and theres then i would be interested.....that is of theres showed better volume for said psi!!!
Old Jun 26, 2006 | 05:40 PM
xtremexj's Avatar
Wanna - no flow numbers listed on E-bay. With more research one could probably find that info.
Flash - a side by side comparison would be awesome!
Old Jun 26, 2006 | 05:41 PM
With a core that size it's not going to be as effective at cooling as a stock IC, but it's better than a sharp stick in the eye if you have a non-intercooled truck. That's assuming of course that it can flow enough air to not be a restriction.
Old Jun 26, 2006 | 09:34 PM
DeanM's Avatar
What you have to understand is that a bad intercooler is worse that no intercooler. Because a restrictive intercooler makes you motor work harder. So what you want is a big intercooler with a low pressure drop that also cools the charge. So a small ricer intercooler wouldn't work on a big turbo truck.
Dean
Old Jun 26, 2006 | 10:45 PM
willieboy's Avatar
What would be a small pressure drop? 1.5 psi, more, less? I have seen several that are "advertised" for Trucks. Some of them look to be good size, 3" cores, the size of a radiator, etc... Also, is this something that mounts in front of the radiator, or does it go below? Boost is a new thing for me, so sorry if the question is a little elementary.
Old Jun 26, 2006 | 11:18 PM
Ya piers has the one that is on top of my list....so far!
Don't now what pressure drop would be good or bad thow.
Old Jun 27, 2006 | 10:15 PM
DeanM's Avatar
Less than 1.5 psi is good. My Porsche is close to 0 psi boost loss. You have to be careful with the advertised boost loss figures cause they might be biased. In otherwords when the intercooler is flowing hardly any air there will be very little boost loss.
And yes they go infront of the radiator or any where you can get air across the fins
Dean
Old Jun 28, 2006 | 08:34 PM
I would look at flow numbers more than pressure drop. We drop several psi across the stock IC's, but that is mostly due to the cooling effect.
Old Jun 28, 2006 | 10:33 PM
DeanM's Avatar
Are you sure of that, or could it be that the design sucks. I am going with the design suck theory
92smokin blacky
Jan 14, 2010 09:23 AM
6Stix
Feb 13, 2009 08:32 AM
mullishacrew
Oct 30, 2008 09:29 PM
Marine
Feb 7, 2003 06:32 PM
csaverline
Oct 23, 2002 04:55 PM
