-   1st Gen. Ram - All Topics (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/)
-   -   Injector washers and idle (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/injector-washers-idle-119601/)
ChrisLib Oct 10, 2006 05:06 PM
Finally got around to swapping out the .060 washers on the POD`s with some .020`s. Idle haze is alot less, and funny thing I swear it`s running smoother, especially at idle. Also the idle speed is definitely a bit higher (no tach, but I have a good ear). Could just changing the depth of the injector by .040 make a difference in how the engine runs...or am I imagining things? I made no other changes other than the washers.
mhuppertz Oct 10, 2006 06:47 PM
Well, it raises the compression ration a tiny bit!! I guess the spray pattern for the POD's is optimized for the position the nozzles are in with .020" washers...
That does it, I HAVE to put those thin dudes in there on mine also.
G1625S Oct 11, 2006 06:44 AM
I'm stuck with the .060 adapter sleeves. It got warm yesterday and I ticked some people off with the haze, that's for sure[laugh]
wannadiesel Oct 11, 2006 05:47 PM
The 0.020's put the spray pattern more in the bowl and less on the top of the piston.
Hot Rod 4 Oct 11, 2006 07:52 PM
Where would someone go about getting these .020 washers? Sounds like a great thing to try with my truck. I have had an idle hase ever since I installed these horrible injectors. (Really need to just bite the bullet and buy some EDM's)[guitar]
Jethrro Oct 11, 2006 10:30 PM
Can get the whole washer setup and the coppers for the return lines from your local pump shop or cummins dealer they come in a kit with a whole bunch of stuff you don't need. Jethrro
wannadiesel Oct 12, 2006 03:35 PM
Tell them you need a Cummins B&C injector install kit.
