Injector washers
Injector washers
I'm going help a friend install bosch +40 4 hole injectors and I need to know what washers I need to use. The kit came with some thin ones, some really thick ones, and the injectors already come with an in between size on them.He is looking for fuel mileage so which ones would be good to use?
Thanks everyone.
Thanks everyone.
No sir, if anything they will improve mileage and idle quality, also gives a slight/minute timing advance due to position of the injector tip. But it is minute, very minute, almost unmeasurable/unnoticeable esp with just 40hp injectors and 1/8th timing bump.
By having the spray deeper in the bowl, you'll get a more complete burn, also should help bottom end power a little. You really have to be used to your truck to notice the difference.
fordsux8269
Dec 9, 2005 12:17 AM
