injector pump leak
injector pump leak
Cant pinpiont it exactly but it drains off the very bottom in the middle of the pump it pours when its cold out and drips when in warmer weather. I guess the seals shrink when it cold, and then theres a small leak on top where the line from the ksb goes
On the back side of the pump opposite the KSB is a small cover held by two Torx screws. This is sealed by an O-ring. O-ring is probably blown (pretty common). Removal of pump is required. Use only an o-ring from a injection pump shop, parts store ones won't last.
TJ0993
11-08-2007 10:27 AM
