injector pump
it started to not want to idle when it got hot now it wont rev up but about halfway and it just chugs and it hazes blue ,,,smells like raw fuel ....
no havent re sealed it ...i thought when they start doing this the head or something is worn out......when it gets hot it idles down low and if you pour water on it to cool it it will idle right back up.......but now it wont rev right over half throttle ...my truck has close to 700,000 on it
From everything I have read what you describe with the idle usually means a dying IP. BUT....for $25 and a few hours of work I would still want to try a re-seal....maybe it will start working again? Stranger things have happened.
everyone i called want 850 to rebuild then if the head is wore its gonna cost more ....no one will give a set price........id just like to find a good used one ......
if the pump was wore out would it be hard to start.....it still starts easy i have my grid heaters unhooked and still it will fire right up in 20 degree weather it starts easier if you push the throttle down about 1/4 way....it just started acting like it had a dirty fuel filter or water in the fuel cutting out at wot....then it got worse now half throttle is all she wants....
I bought my rebuild from them. I sent in my core after I installed the rebuilt pump and they gave me the core charge back. Easy Peasy.
Edwin
J fonder was banned
If you are worried about your pump not being charged for extra parts during the rebuild, Edwin's suggestions looks like a good one.
Edwin
Cold, it won't hit hard enough to start. At about 80° engine temp, it pops off like it should, but won't pull much over idle, missing and smoking like crazy. At about 140° it runs almost normal, just a little wimpy. At full warm up, seems to run OK, but won't idle, or start easily.
I'm betting when I get it down to 1/4 tank and top it off with #2, it'll be fine.
