Injector pump 0-rings's
Old Jul 4, 2005 | 05:33 PM
apwatson50's Avatar
Anybody have the part numbers for the throttle shaft, and full fuel screw o'ring part numbers? Mostly the throttle shaft o-ring. I put the 3200gs in and when back together the throttle shaft was leaking fuel. I have a new bushing already just need the o-ring.
thanks, Aaron
Old Jul 5, 2005 | 01:44 AM
Bushy's Avatar
Patron Saint of 1st gens
The Bosch part number for the throttle shaft is: 1-463-161-849 listed as "shaft".
The o-ring is normally part of a new throttle shaft assembly but if you need that number
it is: 1-460-210-008 and is listed as "o-ring".
You may also want to look into getting the breakover spring, part number: 1-464-651-430 listed as: "coiled spring.
The next item which is a "wear item" is the plate with post sticking up that has the post stick in between the ends of the breakover spring...they wear out over time...
That part number is: 1-461-901-489 listed as "control lever.
Hope that helps...
pb....
Old Jul 5, 2005 | 03:11 AM
bgilbert's Avatar
I bought a Bosch VE gasket kit, comes with all o rings gaskets etc, ran about $15 I believe. I'll get the part number if need be.
Old Jul 5, 2005 | 08:06 AM
apwatson50's Avatar
Thanks Bushy thats what I was looking for. The bosch place arround here doesn't like looking up the part numbers, but they usually have the parts.
With 260K on the truck would you recomend replacing all of these pieces? or can you look at them and tell if they should be replaced?
thanks, Aaron
ahire
13
Oct 17, 2008 12:50 PM
BigErksG2
Sep 25, 2008 06:43 PM
12VRoush
Oct 15, 2007 08:00 PM
1320
Mar 8, 2005 08:56 PM
