injection pump removal ?
Old Aug 15, 2011 | 08:22 PM
GIT-R-DONE's Avatar
Is a gear puller required to remove the gear on the end of the injection pump?
I have the timing cover off and all that, ( spare motor ) is there anything else in there to check for besides the KDP ?
Old Aug 15, 2011 | 08:48 PM
sshort's Avatar
you can use a steering whl puller if you have the right bolts & while your in there check the timing case bolts
Old Aug 15, 2011 | 09:27 PM
dodgenstein's Avatar
Use the bolts from the intake elbow (the ones that also retain the grid heaters) with the steering wheel puller. Locktite all the bolts you find under the cover while you have it opened up. IIRC ther are 5 bolts under the cover, some accessible through slots in the gear.
Brian.B
Sep 3, 2014 08:05 PM
tommurray
Feb 23, 2014 10:38 AM
esgdakota
15
Nov 5, 2012 12:18 PM
JonathanFleguel
Nov 25, 2010 09:45 PM
mini14
Mar 1, 2005 10:25 AM
