Im Back
Im Back
Well fellows after at least 6 months of being smokeless, im back, although the truck runs pretty rough right now she fired up and ran down the road.
She smokes like a volcano, spewing ash and soot everywhere. It sounds like a freakin pulling trucks it takes it a while to build boost then she really gets smokeing. Hopefully ill get its all cleared up before too long gonna adjust the valves, and put some fuel additives and fresh fuel in.
I did get a new Cummins Gasket and thinner injector washers. other than that all stayed same cept fer the oil cooler which was bad (didnt know you could blow both) studs are coming soon, as well as 60lb springs (ill be doing that at school, when i take machening) She was missing really bad but after a while idleing and a very slow creep up the road a ways i was almost in the drive what and she really kicked in. Still smokes like crazy (mixture of white and black), and sputters at low idle, any ideas as to whats causing this.
Thats what i thought but since im still in school and my buddy is a lincoln tech gradjamakit he swears its the pump, and another buddy thinks its the injectors miss firing. Next time i go home its getin new fuel, fuel filter and additive.
07Dually
Mar 9, 2007 12:25 PM
Jordan5687
33
Feb 16, 2007 12:37 AM
JoshPeters
Apr 3, 2005 08:13 AM
Rumbles
May 24, 2004 02:26 PM
HG with a Cummins .020 HG? 12mm studs? Firering block and head
?? 60# valve springs? You know, the good stuff!
