ignition switch.
Old Jan 4, 2006 | 03:31 PM
Micaiahfied's Avatar
ignition switch.
i need to know if my switch is hooked up correctly. looking at the back of the switch the first wire on the right is red. that is the constant hot. when i turn the key on all the others get hot... except the third in from the right. a black with pink/red stripe it only gets up to .6 volts. this wire runs to the circut board for the power windows and the a/c fan... any idea what is going on? this is the second replacement ignition switch so that shouldn't be the problem, anyone have a wiring diagram for this! it's on my 91 thanks!
Old Jan 4, 2006 | 04:50 PM
ok, so i checked on my 92 and all the wires accept the last one (yellow) have full voltage when the key is on. the yellow activates the starter. the black w/red wir and pink/black stripe position 3 and 4 from right to left don't give me any voltage when the key is on from the 91... any idea what the heck is going on... i think i am gonna try getting another switch from the store.... if i use a jumper wire everything works.... i am thinking it has to be the switch.
Old Jan 4, 2006 | 05:33 PM
ok....
autozone has 1 switch... LS711 they don't ask if i have tilt... $30ish
Advance has 2 switches... s17s (w/tilt) $65ish... s70 (w/o tilt) $10 ish
o'reilly also has 2 different switches $15 and $45.... anyone know what the deal is?
i have tried 2 of the LS711 and i cannot get power to 2 of the keyed hot wires.
Old Jan 4, 2006 | 06:03 PM
The non-tilt switch won't fit. There are two constant - hot wires going to the switch, perhaps one of them is dead?
Old Jan 4, 2006 | 06:05 PM
do you know which two are the constant hot? that would help a ton. oh and please disregaurd the PM i sent
Old Jan 4, 2006 | 06:07 PM
also... is there anything wrong with putting in an inline fuse instead of a fusible link?
Old Jan 4, 2006 | 06:22 PM
My diagram is for a '93 so it may be different. One is pink with a black stripe, and one is red.
The idea behind a fusible link is to get you to fix the problem rather than putting a new fuse in. Fusible links usually don't blow unless there is a serious problem.
Old Jan 4, 2006 | 06:26 PM
fkmitchell's Avatar
Do you have power windows and ac problems. Its the fusable link. I think its the orange one. Had the same problem. Fixxed it last week.
Old Jan 4, 2006 | 08:37 PM
well one of the PO cut some of the fusible links out and put in regular wire.... wanna the pink with black stipe makes perfect sence... i was trying to pull the whole brake assembly off again, missing the obvious!
Cowhand
Sep 21, 2004 10:42 AM
jman
Aug 25, 2004 05:15 PM
jd03ctd
May 10, 2004 08:06 AM
GaCamper
Dec 1, 2003 08:59 PM
D4Fritz
Mar 16, 2003 03:55 PM
