IFP o-ring question
Old May 16, 2007 | 02:40 PM
McNasty's Avatar
IFP o-ring question
I pulled my pump last week because of a leak and found this.
The question is what do you think caused this? Is this a common occurence?
Also what is that that the o-ring is sealing?
Thanks.
Old May 16, 2007 | 03:07 PM
Was the whole cover missing?
It's not uncommon for them to spring a leak there, put a new o-ring in and drive.
That's the backside of the timing piston.
Old May 16, 2007 | 03:57 PM
McNasty's Avatar
No the cover was there, I took it off because it was the only wet spot. I figure it would be leaking worse than it was if the cover was gone. Then again...
I bought a whole new pump to replace it. Guess I didn't need it.
Would this leaking affect anything else? Would I lose power or anything like that or damage anything?
Thanks.
Old May 16, 2007 | 04:57 PM
It should run OK with the leak, just could be hard to get started if it sat a while.
Old May 18, 2007 | 02:40 AM
bgilbert's Avatar
Did you turn the old pump in for core or still have it??
Old May 19, 2007 | 08:40 PM
McNasty's Avatar
No I kept it.
Old May 19, 2007 | 09:26 PM
pred's Avatar
We All Want It!!!!!!!
Old May 19, 2007 | 09:27 PM
pred's Avatar
All those metal shavings around the old pump are making me cringe!
98.5POS
37
Jan 26, 2007 08:26 AM
HaulinBut
May 12, 2006 03:06 PM
midwestdually
Jan 7, 2006 03:15 PM
StrokeThis2500
Dec 31, 2005 05:19 PM
