idle hagging up?
Old Jun 9, 2008 | 05:51 PM
archer39's Avatar
idle hagging up?
lately my idle has been hanging up after i let off the throttle. the entire throttle cable assembly seems to be hanging up. i tried spaying it with wd-40 but it did not help. in the picture below, i can push on where the red arrow is pointing it goes back where it is suppose to. is there a certain spring in the assembly that is worn out? i can not see anything that is binding that would be holding it up.
Old Jun 9, 2008 | 06:28 PM
ofcmarc's Avatar
Check the auto trans cable. The tend to bind and cause problems like you describe.
Old Jun 9, 2008 | 07:02 PM
ChrisLib's Avatar
Might also want to ck the cross shaft that the cable attaches to. My truck had a TON of slop in it so I could see it being possible that it could bind as well. There is a thread on here somewhere regarding it, Wanna even posted the P/N`s for the bushings IIRC.
Old Jun 9, 2008 | 08:44 PM
archer39's Avatar
ok thanks, there is slop in the TV cables but it did not look to be the problem. i will check again
Old Jun 10, 2008 | 05:31 PM
I've also seen them rusty and sticking. Some polishing and a little lube and things weren't hanging up.
Ram1999
Feb 11, 2007 10:49 AM
pet05
Oct 5, 2006 11:02 AM
rdc
26
Jul 31, 2006 09:17 AM
dieselnewbie
Jan 18, 2005 10:48 PM
steelsoldiers
21
Dec 19, 2002 04:08 PM
