I want to add Cruise Control
Old Nov 5, 2008 | 07:20 PM
nbaggett89's Avatar
Hey does anyone know the easiest and cheapest way to put cruise control on a non-cruise control CTD truck (1985)? thanks!
Old Nov 5, 2008 | 08:18 PM
Richie O's Avatar
366 Spring Chicken
Easiest,, A stand alone aftermarket system.
Old Nov 5, 2008 | 08:48 PM
nbaggett89's Avatar
are there any the you would recommend in particular?
Old Nov 5, 2008 | 09:33 PM
Field_boss_cb's Avatar
I was doing some reseach on this subject sometime ago for my big truck.
From what I found this one seam to be the one to have. Rosta Diesel Truck Cruise Control PN 250-1223, $325.00 But I have not bought one as of yet.
Old Nov 5, 2008 | 09:53 PM
Busboy's Avatar
ARA used to make Chrysler's cruise control. They have an after market kit that looks like factory. One thing to consider is when you re-route the speedo cable to the servo be careful when bending it and if it has developed a "set" (which it probably has by now) then you will also have to replace it as well. To get the wires down the steering column we would cut the plug off and crazy glue it to a long tie wrap, feed it down then cut off the tie wrap and crimp the plug back on.
Old Nov 5, 2008 | 11:00 PM
nbaggett89's Avatar
well from what I found out about ARA, they have been sold out to some company in california. the Rostra one looks pretty good though. Thanks guys!
Old Nov 6, 2008 | 11:40 AM
apwatson50's Avatar
The easiest and cheapest would be a locking hand throttle cable.
Old Nov 6, 2008 | 01:40 PM
pwrtripls1's Avatar
In a perfect world with no wind or hills then thats the way to go.
Old Nov 6, 2008 | 01:41 PM
pwrtripls1's Avatar
I wonder if a Mag Pickup and a Woodward Governor from a GenSet would work, I have lots of those laying around. lol
Old Nov 6, 2008 | 01:55 PM
apwatson50's Avatar
Actually the internal governor assembly in the injector pump does a pretty good job of maintaining speed.
In my dads truck we drove from colorado to ohio with such a cruise control and it did quite well! True your speed will vary a little but if you start slowing down just put your foot on the peddle till you're at the top of the hill.
Aaron
Old Nov 6, 2008 | 03:29 PM
Richie O's Avatar
366 Spring Chicken
The one that was on my 89 had a mag pick up on the driveshaft. The system worked by regulating driveshaft rpms. It did not hook to speedo system.
Old Nov 7, 2008 | 09:14 AM
schamran's Avatar
Mine was made, i think, by UltraCruise. I don't know how good the factory cruise systems work, but it works decent. The only thing is sensitivity, which you can adjust, but if you don't want the speedo needle to move when you set the cruise it is really a rough ride, in our trucks, because it doesn't let the throttle down slow, it just seems to drop it. Mine isn't set up too bad. Also, when you kick the cruise off with the brakes, I always hit the gas first. it takes up all the slack in the driveline, like i said, drops the throttle. I would reccomend factory cruise, but it sounds pretty complicated in comparison to my cruise.
Old Nov 7, 2008 | 10:07 AM
AUGIE DOG's Avatar
Hey guys, Bruiser who is on here told me of a cruise set-up the 4 - WD guys use. Maybe he will answer. If not i will give him a call and he can tell you who makes it. He made it sound like a very simple installation and worked well...Augie
drewkeen
Mar 14, 2010 12:44 PM
drewkeen
Sep 23, 2008 06:21 PM
rbertalotto
May 31, 2008 11:21 PM
Krazeeun
Sep 28, 2007 09:56 PM
mr T
Mar 4, 2006 06:10 PM
