i think its broke?
Old May 15, 2011 | 02:47 PM
bulltamer's Avatar
i think its broke?
i put a 3200 gov spring bumped the timing an 1/8th" a '89 w250 5 speed and tried to crank it, it fired and ran away on me. scary. we turned down the fuel screw and cranked it again it ran great and we ran it pretty hard down the road and pull over it was missing and smoking white drove it easy back to the shop and it was runnin fine but had no power
Old May 15, 2011 | 03:22 PM
cougar's Avatar
Watch for signs of head gasket failure.
Check for turbo damage and/or boost leaks
Old May 15, 2011 | 04:18 PM
BC847's Avatar
1st Generation Admin
Burp the injectors of any trapped air and try it again.
You may be experiencing a common thing with turned-up VEs where with a WOT run, and side-stepping the throttle, charge-air gets backed-up into a few injectors and makes things run stupid till it clears.
The fix is to roll-off (not fast) the throttle.
Old May 15, 2011 | 08:22 PM
bulltamer's Avatar
alright thanks BC847 and cougar
by burp u mean to bleed?
Old May 15, 2011 | 09:06 PM
BC847's Avatar
Yup. Bleed the air from the injectors.
Old May 15, 2011 | 09:10 PM
bulltamer's Avatar
thanks
smokeum99ta
Dec 8, 2017 01:32 AM
southpawslingr1
Jul 9, 2008 08:44 PM
dodgeman01
May 27, 2004 09:24 AM
DieselDaze
Jul 17, 2003 09:21 PM
