I need help
I need help
About 3 weeks ago I was driving and my truck and it sputtered a little bit and just died. I was thinking that it was the shutoff solenoid so I bought one and replaced it, but it did not fix the problem. I thought that maybe I got a bad part so I took the plunger out and tried to start it and nothing. I checked the lift pump and it is working good. I am getting fuel to the injector pump, but I am only getting fuel to two cylinders very spuratically. I am thinking that it is a bad injector pump. However I know the PO and he says the pump is less than a year old. I have a buddy that recently p-pumped his 1st gen and will sale me his pump for cheap. So I will probably buy it and put it on to see if it will fix it. I hate to keep throwing money at it cause I don't have much time or money to spare. I could really use some advice and help so anything is appreciated.
start by checking the fuel filter and lift pump, the ve's are a tough pump and they can suck there own fuel, just a little bit, then if its still doing the same maby go to the shop that rebiult it and see if you can get any warrity, usaly a rebiuld pump is good for a years warrity, try taking the plunger out of the electric cylinoyed and putting just the top peise back in, i know that fixed my problem awhile back
joel
joel
I took the plunger out and still wasn't getting any fuel. I don't know whats going on. I will have to see if they will warranty it. I've checked everything leading up to the injector pump so thats why I'm thinking it is the IP.
smokin24v
Mar 18, 2008 01:21 AM
pwrtripls1
Feb 8, 2008 07:25 PM
spooling
Sep 13, 2007 10:05 PM
