I am starting to be sorry I installed the fass
I got my fass system installed a few weeks ago and I just started to notice some loss in fp after I put fuel in it the other day. I must have some bad fuel that is clogging the fuel filter but I cannot find any locally anywhere. I called around and everyone said I would have to buy a case of filters. Fleetgaurd is the only one that makes them. I called fass and they sold me filters but I never thought to order a couple water seperators since they are the same deal I have to buy them by the case. With shipping the filters were 75 dollars from fass. The guy at fass told me some filter numbers that I could use in a pinch but that was bad info also. I bought the wix filter he told me to get and it was too short the dip tube for the filter hit the bottom of the filter before the threads caught. I cut the dip tube shouter only to find that the gasket is way too big and dosent seal at all. I hit the key and spilled fuel all over. If I knew that it would be a big deal to buy filters I never would have put the pump on my truck. I might just take it off and install the piston lp I am so mad right now.. I hate when you spend good money for something only to find out that they engineered something very poorly. Why couldnt they just use a common filter that way it would be no big deal to replace them.
I called them and they told me to go to my local fleetgaurd dealer. I told them that I already did that and the only warehouse that had them in stock was in mexico!!!!! Fleetgaurd moved all their operations to mexico recently and shut down production for a little while so stock is scarce from what I was told.
Yep that fleetgaurd statment is ture. I will no longer be running FG on my trucks! I'm sorry to hear about your problems. Have you tried napa. they can cross all FG #'s with their brand of filter. That may work out for you? I'm not sure what else to tell you besides....Good luck
Our shoulders are here for everyone. You rant all you want to. Nothing makes me mad to spend money and get pooped on in the long run! I cant believe as popular as they are that other people havent found a cheaper replacement filter. Have you posted this question on the 2nd gen section? They use them more than anyone I believe!
